I'd like to use a TPS61322 on my circuit to boost the voltage from an AAA battery to 2.2V.
I read the datasheet and the min input voltage is 0.9V, my question is how can I disable the output when the input goes below 0.9V ?
I designed many voltage regulator, and I used SVS to disable the chip when the input was too low, but in this case the TPS61322 don't have the EN pin.
Can you suggest a solution o a different regulator ?
Thank you
Riccardo
