BQ27320: Questions for Datasheet
Part Number: BQ27320
Other Parts Discussed in Thread: BQ2022A
Help customers to post questions in bq27320 DS.
1. BAT_LOW pin:
We have found BAT_LOW define in Functional Block Diagram , reference schematic and layout example. But BAT_LOW is not defined as pin function. Customers are confused on this. Seems like SDQ and BAT_LOW is the same pin, but it's separated in functional block diagram. Also, we cannot find BAT_LOW description in TRM.
2. Working with bq2022A:
DS mentioned this device can work with bq2022A with SDQ pin. But no clear description how to work with bq2022A in bq27320.
  • Hi Ake
    -Bat-low is non-existent in the TRM because it was taken out.
    - For point two you will have to take this offline with the apps engineer responsible for this device.
    thanks
    Onyx
