Other Parts Discussed in Thread: LM317, BQ25600D, BQ25600DEVM-771, BQ25895
Hi trying to design a handheld device powered by 2 NiMH cells. And USB is required to charge the 2 NiMH cells when connected.
Is BQ2002 the best option?
And I’m most likely will not put a thermistor in the design, does the bq2002 work without a thermistor?
And also the room on my circuit board is limited, can you recommend a charging IC that will yield a simpler or just physically small circuit? The bq2002 evaluation board (DV2002L2/TL2) looks very big, I assume the big heatsink is for the LM317? Can you recommend a smaller replacement for LM317 to power from USB 5V?
