TLC5955: Layout recommendations
Part Number: TLC5955
I am working on a design that has a couple of questions based on the schematic provided.
1. VLED (LED supply voltage) and VCC are tied together.
2. All driver output pins are crossed to form a column of data , i.e., they do not follow the layout example of figure 36 in the TLC5955 spec sheet. The outputs are physically organized with channel 0 at the bottom of the PCB and channel 15 at the top of the PCB.
Is this recommended or acceptable?
-Bob
