Other Parts Discussed in Thread: TMS570LC4357, , TMS570LS1227
Hi Team,
My customer used TPS65381A-Q1 to provide power to TMS570LC4357, the TPS65381A-Q1 reported ABIST failure in such condition:
-Enabled Watchdog of TPS65381a, Powered on, TMS570LC4357 worked as normal, TPS65381A is in ACTIVE mode;
-Using JTAG connected the LMC4357 to computer, stopped the software to feed the TPS65381a watchdog;
-TPS65381A reseted, and switch from ACTIVE mode to SAFE states, then to RESET, and then to DIAGNOSTIC, the ABIST failure reported.
-Change the TMS570LC4357 to TMS570LS1227, do the same procedure as previous description, no ABIST failure reported.
Could you kindly give comments which will influence the ABIST failure while using TMS570LC4357? is it link to the power consumption of the controller or not? Expect for your comments, thanks.
Best Regards
Benjamin
