Part Number: BQ24160
Other Parts Discussed in Thread: BQ25600
Good day!
I want to use this: BQ24160 in my design. While going through the datasheet I came across few doubts, please let me get clarifications on them.
Expecting functions from this IC are - Power path management between AC IN, USB and Battery sources. When there is no AC IN or USB it should automatically connect battery supply to Load, and when there is either AC IN or USB the battery should get charged.
1. Does it require external P-channel MOSFET for fulfilling above requirement??
2. What are the limitations/functionality effects(if any) if I keep D+ and D- signals unconnected??
3. I2C alone can be used to program the IC right, does it require USB interface for anything?? Can I get a reference for making good communication between MCU and the Battery charger IC thorough I2C lines??
4. Can you suggest the better alternative for this part if you have??
Thanks in advance.
