LM5145: Dual phase operation, fault detection
Part Number: LM5145
Hello team,
Now I am considering fault detection on LM5145 dual phase operation. I referenced below blog for LM5145 dual phase current sharing schematic.
Other Parts Discussed in Post: LM5145 I’m often asked, “Can you tie the outputs of two voltage-mode buck controllers together, and will the currents in each phase share evenly?” Many experienced designers…
Is it possible to detect whether there is any troubles or there is no trouble on LM5145 dual phase operation?
For example, if below conditions are happened for some reason, how can we detect that the circuit has a trouble?
1). MASTER: Normal, SLAVE: Trouble(for example, FET doesn’t work and current doesn’t flow, and so on)
2). MASTER: Trouble(for example, FET doesn’t work and current doesn’t flow, and so on), SLAVE: Normal
