Hi Tier
I us BQ24610 encountera problem :
1、16V input work ok
2、24V input normal work, about 30 minutes later.Inductance and BQ24610 heating.until the device is damaged.
How to solve this problem?
Hi Tier
1、16V input work ok
Tony,
First, you want to check the PH node and make sure the voltage is not higher than 30V. It is more likely that the power loss is too high for 24V operation. The options to reduce the power loss are:
- use lower Rds-on FETs and lower DCR inductor
- improve PCB layout to increase the copper areas for FET heat dissipation.
Thank you for your reply.
1, test PH pin Vmax=28.4V using an oscilloscope .
2. Changed low rds the MOSFET. and changed low DCR inductor.
but the heat is still very large
Thank you for your reply!
Whether you can supply source files about BQ24610 EVM。thanks!
