Other Parts Discussed in Thread: UCC28070
My question is how the UCC28070 works at the beguinning of operation in simulation because no current is following therefore the PWM output are disabled and cannot active switch. the how we can start opertating the UCC28070 at beguenning of simualtion.
i use a shunt resistor instead of current transformer, then i cannot use your excel design tool for calculation of the components of the UCC28070, could you tell me if there are change in the formula given on datasheet by using shunt resistor.
