TPS7B63-Q1: PG status of TPS7B63-Q1
Part Number: TPS7B63-Q1
Hi
I have a question about PG status of TPS7B63-Q1.
If Vin falls below an internal UVLO threshold, is PG status Hi-Z or Low?
Yokota
  • Hi Yokota,
    The power good signal is only ensured when Vin is above the minimum input voltage. The gate of the pulldown FET on PG is driven from the IN pin. When Vin falls below the UVLO threshold, PG will be logic low as long as Vin is high enough to continue to drive the gate of the pulldown FET.
    Very Respectfully,
    Ryan
