I just ordered the EVM starter kit, installed the software and driver. IT detects the EV2300 when I plug it in, but when I start the software, it doesn't autodetect the board (which I believe it is supposed to) and when I select the correct chip (bq20z80 V102) it tells me that the software wasn't designed for that chip, and won't read anything from it. I can get a more descriptive error message if needed. The only instructions I was able to find are that for the first time using it (which this is) you should "plug" in the leads from the battery pack to the Pack+ and Pack- leads. I tried doing that, but it seems to make no difference at all.
I was mostly just wondering if there was a starter guide for someone who is new to this kind of work (it is a lot different than the FPGA's I am used to) with step by step instructions on how to get it running.
Allen
