UC2825: uc2825
Part Number: UC2825
sir how to vary the duty cycle using that ni which value we need to vary
  • Hi harsha s r,
    To generate a duty cycle you will need to have a capacitor connected between the CT pin and GND and a resistor connected between the RT pin and GND. The Ramp pin must be connected to CT so that you have a triangle wave on the non-inverting input of the comparator.
    The duty cycle will now be controlled by the voltage level on the E/A Out pin. The EA Out voltage can be adjusted using the Open Loop Laboratory Test Fixture shown on page 8 of the datasheet.
    Joe Leisten
