Other Parts Discussed in Thread: TPS2412
Hi!
I am currently planning on using the LM5050-1 for an ORing circuit with a nominal 5V supply. The minimum voltage range on this rail could reach 4.75V (5% tolerance worst case across temperature). I saw on another post the comment below:
"We don't guarantee operation below 5V. But however device would work slightly below 5.0V, till about 4.9V." (https://e2e.ti.com/support/power_management/switches/f/949/t/684316?tisearch=e2e-sitesearch&keymatch=LM5050-1
Could you elaborate more on the failure mode that we could expect if the voltage did drop below 5V?
Thanks!
