BQ76PL455A: Value of Balancing Resistor
Part Number: BQ76PL455A
Hello All,
I am designing a PCB for BMS using bq76pl455 ic. In BQ76PL455 EVM Ti has used a balancing resistor of 75 ohms which provide maximum balancing current of 56mA. So I wanted to ask whether 56 mA current will be sufficient to balance the cells or I should lower the value of resistor?
Also, if we use a lower resistor value what precautions should be taken while designing PCB?
Gunit
