0701
Other Parts Discussed in Thread: TPS63070
Hello guys,
i have a problem with TPS63070  Buck-Boost Converter. The FB-PIN shows the correct voltage, but the output voltage is independent of this pin. It is constant 11V.
i also checked the PG-PIN and the EN-PIN. The Power Good Status says that the output voltage is below power good threshold, which is not correct. I expect a output voltage of 6 V.
I am not a native english speaker. Could you please consider it by answering the question ! Thanks for your help !
