WEBENCH® Tools/TPS54335A: the upper resistor divider at TPS54335A
Part Number: TPS54335A
I am trying to design buck converter using TPS54335A and every time that I'm running WEBENCH Design Tools the value of the upper resistor divider at the output voltage (RFb1 from the output node to the VSENSE pin) is 100Kohm.
Is it possible to use a value above 100Kohm (lower no-load current)?? is this may affect the no-load operation?
