I use TLC59116 RHB package. I have problem with TLC59116 power on. I use switch MIC94091YC6 for managing power on TLC59116.
* When I enable power through switch, VCC pin on TLC59116 fall down to about 0.6V.
* When I don't use switch for power managing and I directly connected VCC to 3.3V , power supply on TLC59116 was 3.3V
When I set the same conditions for TLC59116 PW package, power supply is good with switch and without switch. Output of my switch (image below) is connected on power supply of TLC59116 RHB.
Also. you can see application schematics on below image
Thank you in advence,
Nikola
