Current measurement of bq78pl114
Other Parts Discussed in Thread: BQ78PL114
Due to mechanical restriction it is not possible to set the current measurement shunt between Ubat- and PACK-, but only between V1 and V2. Seems that then the voltage shift of the current measurement is required. Are there any low power recomendation solutions.
Is battery balancing and voltage protection still posible with bq78pl114 when there is no current measurement implemented. How set the standby, normal mode, balancing in that case for the IC algorithm.
Thank you for your answers, Evgen
