Other Parts Discussed in Thread: TPS2816,
I am using this IC to drive a MOSFET. When I check the datasheet there is a application circuit. But this circuit does not use the internal voltage regulator. I was wonder if someone can provide a typical application circuit using the internal voltage regulator?
Thank you.
