TPS53641: SVID Interface AC timing waveforms
Part Number: TPS53641
The datasheet does not contain the SVID interface AC timing details to check its compatibility with Intel Xeon processor SVID interface. Kindly provide the same for the up said TI part
TPS53641
  • Hi, as I replied in another thread that TPS53641 is designed to follow Intel SVID spec rev. 1.7 for VR12.5 processors. The AC timing waveforms will be varied based on the layout and impedance, but as long as you follow Intel SVID guideline layout/pull-up/terminations etc., there will be no SVID issues. If you have any particular designs would like to get reviewed, please send it to us.
