I have been using LMZ23608 as voltage regulator for one year and I get very good results. I have been using a Voltage constant control mode by RFBT and RFBB, but I wonder If I could use a Power constant control mode leaving unmounted RFBT and RFBB and using Share Pin to control the Output. Perhaps, I could mount RFBT and RFBB to set the nominal output, and then, use Share Pin to adjust Dynamically.
If it is not possible, could you help giving me an alternative? I would need a DC/DC converter with a remote sense pin and a Trimmer option.
Thank you in advance for the help.
