Tool/software: TI-RTOS
Our company bought the wireless charging DEMO board from your company on june 27 .We tested and found some problems
1>The distance between the transmitting and receiving is not enough .test result does not exceed 2mm (test method: use 2mm thick plastic place to between TX and RX . appear no receiving problem ) we have compare other brand of wireless charging .as used same test result is 8mm that is good result.
2>The transmitting and receiving offset distance is not enough (The offset distance does not exceed 6mm) .we have compare other brand of wireless charging .as used same test result is 8mm.
remark: The main chip model used is bq501210evm-756. Please analyze the cause of failure and can send email to my 644524113@qq.com
thanks! ang best regards.
