Hello
Customer is seeing frequent shutdown issue with TPS7B7702-Q1 due to short to battery protection in cold cranking test. Output voltage setting is 10.5V for AM/FM antenna. From the scope shot, it looks input voltage drops more quickly than output voltage and it leads latched shutdown due to short to battery protection. Customer may reduce output capacitor(2x 10uF) to discharge output voltage faster but it may affect RF sensitivity, so customer doesn't want to change output capacitance.
Customer changed the schematic to check nERR pin to toggling EN pin during this event, but they want to check if there is any other solutions to avoid this kind of shutdown.
Sam
