Hi All,
I need your suggestion for my requirement
There is 3 USBs which will get connected to Power(5V) only when button is pressed.
Detecting switch pressed can be done by simple Controller , to avoid this want to use Toggle IC which will send 0 or 1 based on Switch pressed.
This requirement is to avoid Coding part for Controller
Push Button ----------------- Toggle Switch -------FET--------- USB
Suggestion required on Toggle Switch which can do toggling states 0 to 1 or vice-versa
