TPS62147: About GND/AGND Layout
Part Number: TPS62147
Other Parts Discussed in Thread: TPS62148
My customer has a aquestion about TPS62147&TPS62148.
Is there a problem with wiring GND and AGND without separating the input side and the output side?
In the Layout example of the data sheet, it is the same.
If it is an application that needs to consider noise, should GND be separated?
When separating, please teach parts to be wired to GND / AGND respectively.
Thank you.
