I found unclear points for VCR pin divider and Burst mode setting, please let me know below points.
①Calculation for VCR pin divider(Datasheet page 52)
What value is Icomp current?
Is Icomp current the same as Iramp (1.84mA_Typ)?
②Burst mode setting (Datasheet page 53)
Datasheet P53 is described "VLL level can be measured by inserting a 10-kΩ resistor between the feedback optocoupler emitter and ground.".
I attached schematic by UCC25630x EVM, I think that 10kΩ resistor is connect to R32, is it correct?
And, where is correct test point on below circuit? (For example, nearly FB pin, nearly optocoupler emitter side, or the other point...)
Satoshi
