Part Number: TPS55340
What will happen if the NC pin is remain unconnected( no connection to ground).
Hi Shafeeq,
It will has the potential risk of coupling a noise at this pin and may let the highest pin voltage higher than abs voltage, which is around 3V. So suggest you connect NC pin to GND.
