TPS40210: Please help to review TPS40210 schematic
Part Number: TPS40210
Hi TI Experts,
I have designed a power board based on TPS40210, which takes an input between 18VAC~30VAC and converts it to 12VDC @1.4A output. The design seems doesn't work because I could not get the required output power. Would you please kindly help to review my design and check if you could find any issue. Thank very much.
Peterpowerboard.pdf
