variable output buck converter
Other Parts Discussed in Thread: TPS62147, TPS54628, TPS62135, TPS62180, TPS54824
I want to design a variable output buck converter with a DAC,  voltage 1-5V, current 2A max. Input voltage is 12Vdc.
Since the output will be PI controlled to drive a TEC, Vout needs to respond rather quickly to the desired point. I am worried about the stability when I am driving different dc voltage into the FB pin.
Which buck converter is most suited for such appliction? Please recommend a buck converter.
