Part Number: TPS2115A
Hi team,
We have some questions for the TPS2115ADRB and this part can be adjusted current limit range up to 2A.
1. May I know what's the current limit accuracy formula or % ratio for min and max?
What's the min and max current limit accuracy if we adjust RILIM= 250ohm?
2. The application may need a moment about 1mS to 2.2A.
Is that set RILIM= 250ohm OK for the application?
We are afraid that will detect to limit output current and the TPS2115A cannot be used here.
Thank you!
