Other Parts Discussed in Thread: LM5576
In the datasheet, the PB_IN pin is connected to 5V internally and can be connected to GND externally with LOW level enabling.
However, when I use TPS65217C, some TPS65217C can work with PB_IN float and some TPS65127C can work with PB_IN connected to GND.
So what is the correct method to handle the PB_IN pin? Is it proper to connected to high level or GND by a specific resistor?
