Other Parts Discussed in Thread: BQSTUDIO, EV2400,
Hey all,
I am currently using the BQ40Z50EVM R1 fuel gauge to track battery information. I was having some problems regarding SoC measurements.
Some background: I used the EV2400 with BQstudio to verify my readings were correct. I can obtain correct pack voltage, current, and other peripherals. However, when reading SoC I will either get 0 or occasionally 100 (100 is more rare). I am using a 3-cell series configuration. I have the correct ChemID pushed onto the board.
I was looking through the specification sheet and saw that Relative SoC will be updated after a discharge/charge, and was curious if a full discharge and charge cycle is required to get an accurate Relative SoC reading.
Another question I have is if there is a procedure in any of the technical documents for the BQ40Z50 for setting Design Capacity and Design Voltage? The older BQ27441 had a procedure for setting those parameters, but I was not able to find any similar procedures in the BQ40Z50 documents. (For reference, the procedure for the BQ27441 can be found on page 14 of this manual: http://www.ti.com/lit/ug/sluuac9a/sluuac9a.pdf ).
Please let me know if anyone has had any similar issues to this, or if they know of any common fixes to this problem.
