I am using TPS610997 regulator to boost 1.5V to 5V. Everything works fine but if the boost is connected to a load more than 50mA, I am unable to disable the regulator. At present, boost's enable pin is tied to 100K pull down to ground and a mosfet is used to switch the enable pin to 1.5V. Please suggest.
Manoj
