BQ28Z610: Bq28z610 Learning cycle "Charge Battery to Full" problem
Part Number: BQ28Z610
Other Parts Discussed in Thread: BQ78Z100
I am trying to learn how to do a learning cycle bq28z610 with 2 cell configuration using APR18650M1 (1100mAh) batteries with EV2300.
1st) ChemID was configured.
2nd) Calibrated current/cellvoltage
3rd) Discharged:
I was able to discharge the batteries by:
1) Enable "Fet_EN" & "Gauge_EN" + "RESET" in command
2) At the end of discharge IT Status (low) - REST bit was set
To charge batteries:
1) Enable only "Gauge_EN" & apply 7.4V (1A) Charge to VPack+ & Vpack-
Issue:
1) FC bit never sets. Only FD bit is set after discharge.
2) Charging Current only shows 88mA
3) Charging Voltage shows 8200 mV.
I'm not really sure what needs to be configured or changed.
I've included gg.csv file for the configuration I currently have.
Thank you in advance for the help
    Your thread has been assigned to me. Please expect an answer in 5 working days or less.
  • Mingyu,
    I don't have your gg file in the post. 7.4V is not a proper charging voltage. 8.4V is. I suspect your config is wrong or your charging voltage is wrong. FC will set only after you reach primary charge termination. At 7.4V you will not. Charge termination opens at 8125mV per defaults and your current has to be less than taper current for 80s. Hope this helps.
  • Hi Batt,
    I've uploaded the gg file for the configuration I have currently.
    Here are some extra questions I have for you:
    1) Which configurations are "mandatory" before proceeding with learning cycle?
    For example: taper current/discharge current/etc.
    2) If I set taper current to be 10% of fast charging current for my battery (400mA), what should I set my discharge/charge/quit current?
    3) Does the "Fet_en" & "Gauge_en" have to be set for charging or just "Gauge_en" shown in "How to Complete a Successful Learning Cycle for the bq28z610/bq78z100"
    Thank you in advance for the help.
    Mingyu
    * Texas Instruments Data Flash File
    * File created Tue Aug 28 16:50:23 2018
    * Device Number 2610
    * Firmware Version 0.17
    * Build Number 22
    * Order Number 0
    * bqz Device Number 2610
    * bqz Firmware Version 0.17
    * bqz Build Number 22
    * Field Order: Class name  Subclass name  Parameter name  Parameter Value  Display Units
    Calibration Voltage Cell Gain 12104 -
    Calibration Voltage Pack Gain 46346 -
    Calibration Voltage BAT Gain 23847 -
    Calibration Current CC Gain 1.034 mOhm
    Calibration Current Capacity Gain 1.034 mOhm
    Calibration Current Offset CC Offset 0 -
    Calibration Current Offset Coulomb Counter Offset Samples 64 -
    Calibration Current Offset Board Offset 0 -
    Calibration Current Offset CC Auto Config 0 hex
    Calibration Current Offset CC Auto Offset 0 -
    Calibration Temperature Internal Temp Offset 0 °C
    Calibration Temperature External1 Temp Offset 0 °C
    Calibration Internal Temp Model Int Gain -12143 -
    Calibration Internal Temp Model Int base offset 6232 -
    Calibration Internal Temp Model Int Minimum AD 0 -
    Calibration Internal Temp Model Int Maximum Temp 6232 0.1degK
    Calibration Cell Temperature Model Coeff a1 -11130 -
    Calibration Cell Temperature Model Coeff a2 19142 -
    Calibration Cell Temperature Model Coeff a3 -19262 -
    Calibration Cell Temperature Model Coeff a4 28203 -
    Calibration Cell Temperature Model Coeff a5 892 -
    Calibration Cell Temperature Model Coeff b1 328 -
    Calibration Cell Temperature Model Coeff b2 -605 -
    Calibration Cell Temperature Model Coeff b3 -2443 -
    Calibration Cell Temperature Model Coeff b4 4696 -
    Calibration Cell Temperature Model Rc0 11703 -
    Calibration Cell Temperature Model Adc0 11703 -
    Calibration Cell Temperature Model Rpad 0 -
    Calibration Cell Temperature Model Rint 0 -
    Calibration Current Deadband Deadband 3 mA
    Calibration Current Deadband Coulomb Counter Deadband 9 116nV
    Settings Protection Protection Configuration 0 hex
    Settings Protection Enabled Protections A 57 hex
    Settings Protection Enabled Protections B 35 hex
    Settings Protection Enabled Protections C 14 hex
    Settings Protection Enabled Protections D 0c hex
    Settings Permanent Failure Enabled PF A 0 hex
    Settings Permanent Failure Enabled PF C 0 hex
    Settings Configuration Charging Configuration 0 hex
    Settings Configuration Temperature Enable 3 hex
    Settings Configuration DA Configuration 11 hex
    Settings Configuration FET Options 20 hex
    Settings Configuration I2C Gauging Configuration 4 hex
    Settings Configuration I2C Configuration 1 hex
    Settings Configuration Power Config 0 hex
    Settings Configuration IO Config 2 hex
    Settings Configuration SOC Flag Config A 0c8c hex
    Settings Configuration SOC Flag Config B 8c hex
    Settings Configuration Balancing Configuration 1 hex
    Settings Configuration IT Gauging Configuration 14de hex
    Settings AFE AFE Protection Control 70 hex
    Settings AFE ZVCHG Exit Threshold 2200 mV
    Settings BTP Init Discharge Set 150 mAh
    Settings BTP Init Charge Set 175 mAh
    Settings Charger Device Address d4 hex
    Settings Charger Voltage Register 0c hex
    Settings Charger Current Register 0a hex
    Settings Charger Broadcast Pacing 15 s
    Settings Manufacturing Mfg Status init 8 hex
    Protections CUV Threshold 2500 mV
    Protections CUV Delay 2 s
    Protections CUV Recovery 3000 mV
    Protections COV Threshold Low Temp 4300 mV
    Protections COV Threshold Standard Temp 4300 mV
    Protections COV Threshold High Temp 4300 mV
    Protections COV Threshold Rec Temp 4300 mV
    Protections COV Delay 2 s
    Protections COV Recovery Low Temp 3900 mV
    Protections COV Recovery Standard Temp 3900 mV
    Protections COV Recovery High Temp 3900 mV
    Protections COV Recovery Rec Temp 3900 mV
    Protections OCC Threshold 6000 mA
    Protections OCC Delay 6 s
    Protections OCC Recovery Threshold -200 mA
    Protections OCC Recovery Delay 5 s
    Protections OCD Threshold -6000 mA
    Protections OCD Delay 6 s
    Protections OCD Recovery Threshold 200 mA
    Protections OCD Recovery Delay 5 s
    Protections AOLD Recovery 5 s
    Protections AOLD Threshold f4 hex
    Protections ASCC Recovery 5 s
    Protections ASCC Threshold 77 hex
    Protections ASCD Recovery 5 s
    Protections ASCD Threshold 1 77 hex
    Protections ASCD Threshold 2 e7 hex
    Protections OTC Threshold 55 1°C
    Protections OTC Delay 2 s
    Protections OTC Recovery 50 1°C
    Protections OTD Threshold 60 1°C
    Protections OTD Delay 2 s
    Protections OTD Recovery 55 1°C
    Protections UTC Threshold 0 1°C
    Protections UTC Delay 2 s
    Protections UTC Recovery 5 1°C
    Protections UTD Threshold 0 1°C
    Protections UTD Delay 2 s
    Protections UTD Recovery 5 1°C
    Protections PTO Charge Threshold 2000 mA
    Protections PTO Suspend Threshold 1800 mA
    Protections PTO Delay 1800 s
    Protections PTO Reset 2 mAh
    Protections CTO Charge Threshold 2500 mA
    Protections CTO Suspend Threshold 2000 mA
    Protections CTO Delay 54000 s
    Protections CTO Reset 2 mAh
    Permanent Fail SOV Threshold 4500 mV
    Permanent Fail SOV Delay 5 s
    Permanent Fail CFET OFF Threshold 5 mA
    Permanent Fail CFET OFF Delay 5 s
    Permanent Fail DFET OFF Threshold -5 mA
    Permanent Fail DFET OFF Delay 5 s
    Advanced Charge Algorithm Temperature Ranges T1 Temp 0 °C
    Advanced Charge Algorithm Temperature Ranges T2 Temp 12 °C
    Advanced Charge Algorithm Temperature Ranges T5 Temp 20 °C
    Advanced Charge Algorithm Temperature Ranges T6 Temp 25 °C
    Advanced Charge Algorithm Temperature Ranges T3 Temp 30 °C
    Advanced Charge Algorithm Temperature Ranges T4 Temp 55 °C
    Advanced Charge Algorithm Temperature Ranges Hysteresis Temp 1 °C
    Advanced Charge Algorithm Low Temp Charging Voltage 4000 mV
    Advanced Charge Algorithm Low Temp Charging Current Low 132 mA
    Advanced Charge Algorithm Low Temp Charging Current Med 352 mA
    Advanced Charge Algorithm Low Temp Charging Current High 264 mA
    Advanced Charge Algorithm Standard Temp Charging Voltage 4200 mV
    Advanced Charge Algorithm Standard Temp Charging Current Low 1980 mA
    Advanced Charge Algorithm Standard Temp Charging Current Med 4004 mA
    Advanced Charge Algorithm Standard Temp Charging Current High 2992 mA
    Advanced Charge Algorithm High Temp Charging Voltage 4000 mV
    Advanced Charge Algorithm High Temp Charging Current Low 1012 mA
    Advanced Charge Algorithm High Temp Charging Current Med 1980 mA
    Advanced Charge Algorithm High Temp Charging Current High 1496 mA
    Advanced Charge Algorithm Rec Temp Charging Voltage 4100 mV
    Advanced Charge Algorithm Rec Temp Charging Current Low 2508 mA
    Advanced Charge Algorithm Rec Temp Charging Current Med 4488 mA
    Advanced Charge Algorithm Rec Temp Charging Current High 3520 mA
    Advanced Charge Algorithm Pre-Charging Current 88 mA
    Advanced Charge Algorithm Maintenance Charging Current 44 mA
    Advanced Charge Algorithm Voltage Range Precharge Start Voltage 2500 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Low 2900 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Med 3600 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage High 4000 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Hysteresis 0 mV
    Advanced Charge Algorithm Termination Config Charge Term Taper Current 70 mA
    Advanced Charge Algorithm Termination Config Charge Term Voltage 75 mV
    Advanced Charge Algorithm Cell Balancing Config Bal Time/mAh Cell 1 367 s/mAh
    Advanced Charge Algorithm Cell Balancing Config Bal Time/mAh Cell 2 514 s/mAh
    Advanced Charge Algorithm Cell Balancing Config Min Start Balance Delta 3 mV
    Advanced Charge Algorithm Cell Balancing Config Relax Balance Interval 18000 s
    Advanced Charge Algorithm Cell Balancing Config Min Rsoc for Balancing 80 %
    Gas Gauging Current Thresholds Dsg Current Threshold 45 mA
    Gas Gauging Current Thresholds Chg Current Threshold 40 mA
    Gas Gauging Current Thresholds Quit Current 10 mA
    Gas Gauging Current Thresholds Dsg Relax Time 1 s
    Gas Gauging Current Thresholds Chg Relax Time 60 s
    Gas Gauging Standby StandbyCurrent -10 mA
    Gas Gauging Max Load Max Load Current -500 mA
    Gas Gauging Max Load Max Load Rsoc 50 %
    Gas Gauging Design Design Capacity mAh 4400 mAh
    Gas Gauging Design Design Capacity cWh 6336 cWh
    Gas Gauging Design Design Voltage 7200 mV
    Gas Gauging Cycle Cycle Count Percentage 90 %
    Gas Gauging FD Set Voltage Threshold 2300 mV
    Gas Gauging FD Clear Voltage Threshold 2200 mV
    Gas Gauging FD Set % RSOC Threshold 0 %
    Gas Gauging FD Clear % RSOC Threshold 5 %
    Gas Gauging FC Set Voltage Threshold 3600 mV
    Gas Gauging FC Clear Voltage Threshold 3500 mV
    Gas Gauging FC Set % RSOC Threshold 100 %
    Gas Gauging FC Clear % RSOC Threshold 95 %
    Gas Gauging TD Set Voltage Threshold 3200 mV
    Gas Gauging TD Clear Voltage Threshold 3300 mV
    Gas Gauging TD Set % RSOC Threshold 6 %
    Gas Gauging TD Clear % RSOC Threshold 8 %
    Gas Gauging TC Set Voltage Threshold 3600 mV
    Gas Gauging TC Clear Voltage Threshold 3500 mV
    Gas Gauging TC Set % RSOC Threshold 100 %
    Gas Gauging TC Clear % RSOC Threshold 95 %
    Gas Gauging State Cycle Count 0 -
    Gas Gauging State Qmax Cell 1 1100 mAh
    Gas Gauging State Qmax Cell 2 1100 mAh
    Gas Gauging State Qmax Pack 0 mAh
    Gas Gauging State Qmax Cycle Count 0 -
    Gas Gauging State Update Status 4 -
    Gas Gauging State Cell 1 Chg Voltage at EoC 0 mV
    Gas Gauging State Cell 2 Chg Voltage at EoC 0 mV
    Gas Gauging State Current at EoC 0 mA
    Gas Gauging State Avg I Last Run 0 mA
    Gas Gauging State Avg P Last Run 0 cW
    Gas Gauging State Delta Voltage 0 mV
    Gas Gauging State Temp k 0 °C/256mW
    Gas Gauging State Temp a 0 s
    Gas Gauging State Max Avg I Last Run -2048 mA
    Gas Gauging State Max Avg P Last Run -3022 cW
    Gas Gauging IT Cfg Load Select 7 -
    Gas Gauging IT Cfg Load Mode 0 -
    Gas Gauging IT Cfg User Rate-mA 0 mA
    Gas Gauging IT Cfg User Rate-cW 0 cW
    Gas Gauging IT Cfg Reserve Cap-mAh 0 mAh
    Gas Gauging IT Cfg Reserve Cap-cWh 0 cWh
    Gas Gauging IT Cfg Design Resistance 0 mOhm
    Gas Gauging IT Cfg Pack Resistance 0 mOhm
    Gas Gauging IT Cfg System Resistance 0 mOhm
    Gas Gauging IT Cfg Ra Filter 80 %
    Gas Gauging IT Cfg Ra Max Delta 15 %
    Gas Gauging IT Cfg Resistance Parameter Filter 65142 -
    Gas Gauging IT Cfg Near EDV Ra Param Filter 59220 -
    Gas Gauging IT Cfg Qmax Delta 5 %
    Gas Gauging IT Cfg Qmax Upper Bound 130 %
    Gas Gauging IT Cfg Term Voltage 4600 mV
    Gas Gauging IT Cfg Term V Hold Time 1 s
    Gas Gauging IT Cfg Term Voltage Delta 300 mV
    Gas Gauging IT Cfg Term Min Cell V 2800 mV
    Gas Gauging IT Cfg Fast Scale Start SOC 10 %
    Gas Gauging IT Cfg Min Delta Voltage 0 mV
    Gas Gauging Smoothing Smooth Relax Time 1000 s
    Gas Gauging Condition Flag Max Error Limit 100 %
    Power Power Valid Update Voltage 2800 mV
    Power Shutdown Shutdown Voltage 2300 mV
    Power Shutdown Shutdown Time 10 s
    Power Shutdown Charger Present Threshold 3000 mV
    Power Sleep Sleep Current 10 mA
    Power Sleep Bus Timeout 5 s
    Power Sleep Voltage Time 5 s
    Power Sleep Current Time 20 s
    Power Sleep Wake Comparator 0 hex
    Power Ship FET Off Time 10 s
    Power Ship Delay 20 s
    Power Ship Auto Ship Time 1440 min
    PF Status Device Status Data Safety Alert A 0 hex
    PF Status Device Status Data Safety Status A 0 hex
    PF Status Device Status Data Safety Alert B 0 hex
    PF Status Device Status Data Safety Status B 0 hex
    PF Status Device Status Data Safety Alert C 0 hex
    PF Status Device Status Data Safety Status C 0 hex
    PF Status Device Status Data Safety Alert D 0 hex
    PF Status Device Status Data Safety Status D 0 hex
    PF Status Device Status Data PF Alert A 0 hex
    PF Status Device Status Data PF Status A 0 hex
    PF Status Device Status Data PF Status D 0 hex
    PF Status Device Status Data Operation Status A 0 hex
    PF Status Device Status Data Operation Status B 0 hex
    PF Status Device Status Data Temp Range 0 hex
    PF Status Device Status Data Charging Status A 0 hex
    PF Status Device Status Data Charging Status B 0 hex
    PF Status Device Status Data Gauging Status 0 hex
    PF Status Device Status Data IT Status 0 hex
    PF Status Device Voltage Data Cell 1 Voltage 0 mV
    PF Status Device Voltage Data Cell 2 Voltage 0 mV
    PF Status Device Voltage Data Battery Direct Voltage 0 mV
    PF Status Device Voltage Data Pack Voltage 0 mV
    PF Status Device Current Data Current 0 mA
    PF Status Device Temperature Data Internal Temperature -273.2 °C
    PF Status Device Temperature Data External 1 Temperature -273.2 °C
    PF Status Device Temperature Data External 2 Temperature -273.2 °C
    PF Status Device Gauging Data Cell 1 Dod0 0 -
    PF Status Device Gauging Data Cell 2 Dod0 0 -
    PF Status Device Gauging Data Passed Charge 0 mAh
    PF Status AFE Regs AFE Interrupt Status 0 hex
    PF Status AFE Regs AFE FET Status 0 hex
    PF Status AFE Regs AFE RXIN 0 hex
    PF Status AFE Regs AFE Latch Status 0 hex
    PF Status AFE Regs AFE Interrupt Enable 0 hex
    PF Status AFE Regs AFE FET Control 0 hex
    PF Status AFE Regs AFE RXIEN 0 hex
    PF Status AFE Regs AFE RLOUT 0 hex
    PF Status AFE Regs AFE RHOUT 0 hex
    PF Status AFE Regs AFE RHINT 0 hex
    PF Status AFE Regs AFE Cell Balance 0 hex
    PF Status AFE Regs AFE AD/CC Control 0 hex
    PF Status AFE Regs AFE ADC Mux 0 hex
    PF Status AFE Regs AFE LED Output 0 hex
    PF Status AFE Regs AFE State Control 0 hex
    PF Status AFE Regs AFE LED/Wake Control 0 hex
    PF Status AFE Regs AFE Protection Control 0 hex
    PF Status AFE Regs AFE OCD 0 hex
    PF Status AFE Regs AFE SCC 0 hex
    PF Status AFE Regs AFE SCD1 0 hex
    PF Status AFE Regs AFE SCD2 0 hex
    System Data Manufacturer Data Manufacturer Info Block A01 61 Hex
    System Data Manufacturer Data Manufacturer Info Block A02 62 Hex
    System Data Manufacturer Data Manufacturer Info Block A03 63 Hex
    System Data Manufacturer Data Manufacturer Info Block A04 64 Hex
    System Data Manufacturer Data Manufacturer Info Block A05 65 Hex
    System Data Manufacturer Data Manufacturer Info Block A06 66 Hex
    System Data Manufacturer Data Manufacturer Info Block A07 67 Hex
    System Data Manufacturer Data Manufacturer Info Block A08 68 Hex
    System Data Manufacturer Data Manufacturer Info Block A09 69 Hex
    System Data Manufacturer Data Manufacturer Info Block A10 6a Hex
    System Data Manufacturer Data Manufacturer Info Block A11 6b Hex
    System Data Manufacturer Data Manufacturer Info Block A12 6c Hex
    System Data Manufacturer Data Manufacturer Info Block A13 6d Hex
    System Data Manufacturer Data Manufacturer Info Block A14 6e Hex
    System Data Manufacturer Data Manufacturer Info Block A15 6f Hex
    System Data Manufacturer Data Manufacturer Info Block A16 70 Hex
    System Data Manufacturer Data Manufacturer Info Block A17 71 Hex
    System Data Manufacturer Data Manufacturer Info Block A18 72 Hex
    System Data Manufacturer Data Manufacturer Info Block A19 73 Hex
    System Data Manufacturer Data Manufacturer Info Block A20 74 Hex
    System Data Manufacturer Data Manufacturer Info Block A21 75 Hex
    System Data Manufacturer Data Manufacturer Info Block A22 76 Hex
    System Data Manufacturer Data Manufacturer Info Block A23 77 Hex
    System Data Manufacturer Data Manufacturer Info Block A24 7a Hex
    System Data Manufacturer Data Manufacturer Info Block A25 78 Hex
    System Data Manufacturer Data Manufacturer Info Block A26 79 Hex
    System Data Manufacturer Data Manufacturer Info Block A27 30 Hex
    System Data Manufacturer Data Manufacturer Info Block A28 31 Hex
    System Data Manufacturer Data Manufacturer Info Block A29 32 Hex
    System Data Manufacturer Data Manufacturer Info Block A30 33 Hex
    System Data Manufacturer Data Manufacturer Info Block A31 34 Hex
    System Data Manufacturer Data Manufacturer Info Block A32 35 Hex
    System Data Integrity Static DF Signature 0 hex
    System Data Integrity Static Chem DF Signature 4238 hex
    System Data Integrity All DF Signature 0 hex
    I2C Configuration Data Manufacture Date 1/1/1980 date
    I2C Configuration Data Serial Number 1 hex
    I2C Configuration Data Manufacturer Name Texas Instruments -
    I2C Configuration Data Device Name bq28z610 -
    I2C Configuration Data Device Chemistry LION -
    Lifetimes Voltage Cell 1 Max Voltage 0 mV
    Lifetimes Voltage Cell 2 Max Voltage 0 mV
    Lifetimes Current Max Charge Current 0 mA
    Lifetimes Current Max Discharge Current 0 mA
    Lifetimes Temperature Max Temp Cell -128 °C
    Lifetimes Temperature Min Temp Cell 127 °C
    Ra Table R_a0 Cell0 R_a flag ff55 -
    Ra Table R_a0 Cell0 R_a 0 56 2^-10ohm
    Ra Table R_a0 Cell0 R_a 1 66 2^-10ohm
    Ra Table R_a0 Cell0 R_a 2 90 2^-10ohm
    Ra Table R_a0 Cell0 R_a 3 56 2^-10ohm
    Ra Table R_a0 Cell0 R_a 4 64 2^-10ohm
    Ra Table R_a0 Cell0 R_a 5 78 2^-10ohm
    Ra Table R_a0 Cell0 R_a 6 76 2^-10ohm
    Ra Table R_a0 Cell0 R_a 7 100 2^-10ohm
    Ra Table R_a0 Cell0 R_a 8 149 2^-10ohm
    Ra Table R_a0 Cell0 R_a 9 186 2^-10ohm
    Ra Table R_a0 Cell0 R_a 10 216 2^-10ohm
    Ra Table R_a0 Cell0 R_a 11 210 2^-10ohm
    Ra Table R_a0 Cell0 R_a 12 269 2^-10ohm
    Ra Table R_a0 Cell0 R_a 13 1500 2^-10ohm
    Ra Table R_a0 Cell0 R_a 14 1500 2^-10ohm
    Ra Table R_a1 Cell1 R_a flag ff55 -
    Ra Table R_a1 Cell1 R_a 0 56 2^-10ohm
    Ra Table R_a1 Cell1 R_a 1 66 2^-10ohm
    Ra Table R_a1 Cell1 R_a 2 90 2^-10ohm
    Ra Table R_a1 Cell1 R_a 3 56 2^-10ohm
    Ra Table R_a1 Cell1 R_a 4 64 2^-10ohm
    Ra Table R_a1 Cell1 R_a 5 78 2^-10ohm
    Ra Table R_a1 Cell1 R_a 6 76 2^-10ohm
    Ra Table R_a1 Cell1 R_a 7 100 2^-10ohm
    Ra Table R_a1 Cell1 R_a 8 149 2^-10ohm
    Ra Table R_a1 Cell1 R_a 9 186 2^-10ohm
    Ra Table R_a1 Cell1 R_a 10 216 2^-10ohm
    Ra Table R_a1 Cell1 R_a 11 210 2^-10ohm
    Ra Table R_a1 Cell1 R_a 12 269 2^-10ohm
    Ra Table R_a1 Cell1 R_a 13 1500 2^-10ohm
    Ra Table R_a1 Cell1 R_a 14 1500 2^-10ohm
    Ra Table R_a0x xCell0 R_a flag ffff -
    Ra Table R_a0x xCell0 R_a 0 56 2^-10ohm
    Ra Table R_a0x xCell0 R_a 1 66 2^-10ohm
    Ra Table R_a0x xCell0 R_a 2 90 2^-10ohm
    Ra Table R_a0x xCell0 R_a 3 56 2^-10ohm
    Ra Table R_a0x xCell0 R_a 4 64 2^-10ohm
    Ra Table R_a0x xCell0 R_a 5 78 2^-10ohm
    Ra Table R_a0x xCell0 R_a 6 76 2^-10ohm
    Ra Table R_a0x xCell0 R_a 7 100 2^-10ohm
    Ra Table R_a0x xCell0 R_a 8 149 2^-10ohm
    Ra Table R_a0x xCell0 R_a 9 186 2^-10ohm
    Ra Table R_a0x xCell0 R_a 10 216 2^-10ohm
    Ra Table R_a0x xCell0 R_a 11 210 2^-10ohm
    Ra Table R_a0x xCell0 R_a 12 269 2^-10ohm
    Ra Table R_a0x xCell0 R_a 13 1500 2^-10ohm
    Ra Table R_a0x xCell0 R_a 14 1500 2^-10ohm
    Ra Table R_a1x xCell1 R_a flag ffff -
    Ra Table R_a1x xCell1 R_a 0 56 2^-10ohm
    Ra Table R_a1x xCell1 R_a 1 66 2^-10ohm
    Ra Table R_a1x xCell1 R_a 2 90 2^-10ohm
    Ra Table R_a1x xCell1 R_a 3 56 2^-10ohm
    Ra Table R_a1x xCell1 R_a 4 64 2^-10ohm
    Ra Table R_a1x xCell1 R_a 5 78 2^-10ohm
    Ra Table R_a1x xCell1 R_a 6 76 2^-10ohm
    Ra Table R_a1x xCell1 R_a 7 100 2^-10ohm
    Ra Table R_a1x xCell1 R_a 8 149 2^-10ohm
    Ra Table R_a1x xCell1 R_a 9 186 2^-10ohm
    Ra Table R_a1x xCell1 R_a 10 216 2^-10ohm
    Ra Table R_a1x xCell1 R_a 11 210 2^-10ohm
    Ra Table R_a1x xCell1 R_a 12 269 2^-10ohm
    Ra Table R_a1x xCell1 R_a 13 1500 2^-10ohm
    Ra Table R_a1x xCell1 R_a 14 1500 2^-10ohm
  • Can you please send me the gg.csv file as an attachment? It's difficult to read it this way or import it and test it.
  • Hi Batt,
    It keeps giving me an error when I try uploading gg.csv file. What other ways can I send it to you?
    Min
  • Hi Batt,
    I decided to convert the file to Excel. Hope this works.
    Min
    Battery Configuration .gg.xlsx
  • Please don't convert it to xlsx. Please upload it as a zip file.
  • Hi Batt,
    Here's the file I have right now. Thanks
    Battery Configuration.zip
  • Hi Mingyu,
    It seems you are just using our default config for the most part which is accurate for 4200mV cells.
    So given that to answer your questions,
    You need to have completely discharged the cell after correctly programming the gauge per the app not instructions.
    Adjust taper current to 1/10th of the C rate.
    Your charge and dsg current can be C/2 and C/5 respectively.
    Your Term V should be about 3200mV or 3000mV.
    You should dsg your battery to 2900mV to ensure that term V is hit during dsg
    During chg you should taper to at least 20mA below your taper current and keep the current on that level for at least 80 seconds
    Quit current should not be changed. For the rest, see above.
    You need to have fets enabled for charging. Therefore send commands 0x21 and 0x20 for GAUGE_EN and FET_EN.
