anyone have any experience working with the bq2014 (not the H but with DQ comm)? Packs are decrementing NAC at a fast rate. Dropping down to zero in a matter of days. any suggestions?
TLHB said:anyone have any experience working with the bq2014 (not the H but with DQ comm)? Packs are decrementing NAC at a fast rate. Dropping down to zero in a matter of days. any suggestions?
Yes I am using 2 banks of NI-MH cells and 2 bq2014 to indicate the state of charge. I am also facing similar problem as NAC decrements down to zero. Can it be a problem with PCB layout where Vsr < Vss ???
I have tried shorting Sr Pin to Vss and then load NACH count through DQ line interface,the system works fine
So it must be something to do with PCB layout/ tracks impedances???
All suggestions are welcome!!!
