Part Number: UCC27714
TI -- UCC27714 2-SWITCH IGBT SWITCH NOT CLOSING.pdf
Hello again Eddie,
I'm sorry to see that you're having so much difficulty getting this design working with UCC27714. Let's try to figure out what's going on.
While looking at your schematic, I noticed that you have timed the closing of Q1 and SH simultaneously, as opposed to the inverted scheme originally presented in the datasheet. As drawn, your schematic creates a shoot-through path for current through Q1 directly into SH. SH must be driven on (closed) only when Q1 is driven off (open). Unless this is an error in the drawing, I suspect this is the major cause of the observed failures.
Please double-check that the schematic as drawn is correct, as this is a critical issue if so. We can return to your other questions if it is not the case that SH and Q1 are being driven simultaneously.
