Hi Bill,
But in our testing, only disable TTDM, then #CHG can goes low when battery insert.
1) According to datasheet 8.4.6, is this descript what I have tested?
If the battery was removed then the CHG terminal will go
to its high impedance state if not already there. If a battery is detected the CHG terminal does not change states
until the current tapers to the termination threshold, where the CHG terminal goes to its high impedance state if
not already there (the regulated output will remain on).
2) Sorry I don't get it. Do you mean I can reduce resistor from 237K?
3) How the 237K be calculated?
