Power Distribution Units EERD
Hi
My customer has a project about PDU.
I found an EERD, but I think this EERD is not similar to this project.
website link: http://www.ti.com/solution/power-distribution-units-ac-and-dc-pdus
Customer project is similar to switchboard.
There are auxiliary power(flyback, fly-buck, LDO), power distribution(OPA, protect, meter, CAN, isolator, monitor MCU) and control board(MCU, power management, sensor, PHY, isolator, CAN).
This project is get meter value, if meter value is too high or too low, MCU will do some action to make sure system is working normally.
Can you provide me more suitable EERD so I can check if there is anything ignore?
Thank you.
  • Hello Wei Hsin,
    TI design solutions are all located here:
    www.ti.com/.../apps-homepage.html
    There is not enough information in your post to suggest a more "suitable" design.
    You mentioned several functions of the design, Power, CAN, etc.
    I suggest searching TI.COM for each subsection.
    Define the system requirements more clearly and your search will have better results.
    Creating a block diagram will help organize the system needs.
    You may need to combine pieces of different designs to create your system solution.
