BQ24172: there is no charging current when connected the battery(no load)
Part Number: BQ24172
I’m writing you to ask a question about BQ24172, the question is that there is no charging current when connected the battery.
The figure 1 is pin-STATE’s waveform,  The figure 2 is pin-SW’s waveform, figure 3:pin-ACDRV, figure 4: pin-REGN
The figure 5 is customer’s schematic.(there is a thermistor in the pin-TS, and he replaced it with a 10k resistor. But he didn’t mark it in the schematic.)
In addition, he connected pin-TTC to pin-VREF.
Could you please help check it and give a solution about it?
Thank you very much!
There are some new developments. When connected TTC to GND, there is a charging current. But I don't know the reason,
could you please help explain it?
Thanks & Best Regards,
Sherry
