BQ24195: Reset following a default
Expert 5100 points
Part Number: BQ24195
Dear e2e Support,
When our charger detect a fault (as a watchdog event), it resets all the registers by a default value.
This behavior doesn't fit to my customer application, where the following parameters need to be kept: Charge voltage limit, Fast charge current limit, Input current limit, Input voltage limit, Minimum system voltage limit, I²C watchdog timer setting.
Is  there any way to save a kind of "custom config" in our IC?
