Hello sir,
We are using LM5008 in BMS and the sleep current is very important for us.
Because of that, we wanted to shutdown the LM5008 when the Battery is under voltage (38V) which is higher than ICs internal Under Voltage lock (5.3V).
But If I pull down RT/SD to ground according to datasheet, then the current through the RT will be 210 uA in my case. Again which is higher than ICs Quiescent current 110 uA.
We need to have shutdown current less than Quiescent current which is around 10 uA. Please let us know how to achieve this.
Akilan G
