Part Number: TPS65170
Dear all,
I'm working on a power management solution for source driver IC of LCD panel. I wish to use TPS651XX family chips to implement the correct power on and off sequencing defined by source driver IC provider.
The power on/off sequencing is as following:
Actually, the power on sequencing of TPS65170 based on its datasheet is matched with the required sequence. However, there is no information of power off sequencing mentioned on its datasheet. I ordered one EVM board for testing and here is my result. As you can see, Vlogic goes away before Vs goes to GND. The load is open in my test. Could any expert could help me how to control the power off sequencing of TPS65170. And is this chip the best option to implement the power management of SDIC?
