BQ25601D: TS not using
Part Number: BQ25601D
Hi
I am using the BQ25601D as our charging IC in an IoT device. But the battery we are going use don't posses a thermal sensor output. So we like to disable the TS pin usage in the BQ25601D by connect a 10-kΩ resistor from REGN to TS and connect a 10-kΩ resistor from TS to GND. Will it support charging the battery in fast and normal charging mode?
