TPS25927: Dual rail protection
Part Number: TPS25927
I have a circuit which, in case of failure or overcurrent, needs both Vcc and GND to be disconnected at the same time. I've been looking around and haven't found anything similar. The possible solution I thought of is an e-fuse with an external fet to disconnect the ground, like the one below.
Would this work?
Federico
