Other Parts Discussed in Thread: TPS65982
Please let me check about confuse point for TPS65282DA function flow, procedure steps is below:
I want to know step ④ is correct or not, and the reason of occur step ⑤.
①When Main board(CPU) shift the state to shutdown, it means that PDC (PD controller) will be set to Sink only by EC.
②No device connect with main board's type-c ports.
③Type-C port CC waveform is attached; CH1 is CC1(Yellow) / CH2 is CC2(Green).
④I think that the CC line need fixed to Rd(Low) when set to sink only.
⑤But from waveform this port declare is DRP, not sink only.
Satoshi
