Other Parts Discussed in Thread: BQ34110, BQ34Z100
Good morning,
we are going to use a battery pack equipped with the BQ34Z100-G1 for a good SOC estimation into a solar luminaire.
In such an application the battery pack is continuously charged and discharged: during day time it is important to maximize the energy collection from the sun through a solar panel for charging the battery, while during the nigh time it is important to guarantee a proper light intensity in the area where the system has bee installed.
So normally there are no relaxation intervals available for the battery because immediately after the sunset the charging phase is disable and light is switched on, while immediately after the sunrise, the charging is enable and light switched off. How the impedance track algorithm can work under such situation?
just in case it would be necessary, we can find a way for leaving the battery pack to relax for a short time. So we would like to ask if that could be necessary/useful and, just in case, which characteristics the relaxation period should have (and some indications about how to set related parameters in BQ34Z100-G1).
Thank you in advance for any suggestion and best regards
Matteo
