Part Number: TPS61165
Other Parts Discussed in Thread: TPS61185, TPS61177A
Hi ,
My customer want to use TPS61165 in a led string case, two led strings in parallel, 10 leds each string. they mentioned each string need 150mA current. and datasheet declares TPS61165 can output to 38V and 300mA output current is no problem. May I have your suggestion if it is ok in this case. if not, what is your recommendation? thanks.
