TPS82140: Availability of part
Part Number: TPS82140
Other Parts Discussed in Thread: TPS82150, TPS62147, TPS82130
When will you ensure the availability of circuit TPS82140 ?
it is risky to plan a study with your circuits
Thank you for your answer
P.R
  • Hi P.R.
    Please place an order and then you get a shipping date from your disti. The entire industry is on tight supply currently, especially with other components such as ceramic caps.
    There is also the pin to pin TPS82130 and TPS82150. If you want to use a discrete solution, with shorter lead times, we have TPS62147/8.
