Other Parts Discussed in Thread: TL431
My customer has a requirement to supply an adjustable constant current source to a Life Science Board. The current source should be adjustable by a MCU, from 0 - 10A. The following diagram show the requirement.
Input is a 20V source, and output is a constant current 0-10A, and the output voltage should be clammed at 14V.
I am not able to find any simple power management solution to fit this case.
Any suggestions to the solution ?
Thanks and regards,
CM.
