TPS2377-1: Mode A and Mode B
Part Number: TPS2377-1
Dear sir/Madam,
I need to design the PoE PD module for the 12W application. I did the design using TPS2377-1.
I have doubt about the Mode A and mode B types of transmission in PoE communication.
How do I make the circuit compatible with Alternative A and Alternative B?
I know Mode B was widely used in small applications. But our client required that power module compatible with both modes(A&B)
and also I need the document for "how to select proper center tapped transformer for different types of  PoE PD application".
  • Hi Vignesh,
    I have restated & answered your questions below.
    1. How can I make my design compatible with Alt-A & Alt-B?
    You can do this by using by adding a additional bridge rectifier for the Alt-B pairs and connecting the output of the bridge rectifier in parallel with the output of the bridge rectifier used for the Alt-A pairs.
    2. How to select a center tapped transformer for PoE?
    Unfortunately, we do not have this document, but check with your magnetics manufacturer. They should be more helpful.
    Thank you,
    Tom A.
  • Vignesh,
    We think this has resolved your issue. If not, please follow up with additional questions/concerns. If so, please click "Resolved" so that we know (and other readers can know) that this was helpful.
    Thank you for your interest in PoE products from Texas Instruments,
